[FS: General] Equinox housing hd10 for sony ex1 brand new
The housing is in very good conditions, just 4 Dives at 30 ft. I will send pictures..
I Recently buy from b&h
HD10-High-Definition-Underwater-Video-Housing.html
Just $ 2,500 us dlls
Product Description
This Equinox HDPRO-10 Underwater Video Housing is design for the following Camcorders
Camcorder
Housing Part#
Sony PMWEX1
Equinox housing constructed from rugged and durable PVC material and one inch cast acrylic front and rear face-plates with stainless steel hardware which eliminates corrosion.
The HDPRO-10 Package Includes
· Equinox HDPRO-10 Video Housing
· 2.5 inch Rear-mounted internal color LCD monitor with rechargeable battery and charger [values at over $400]
· Carrying strap
· EO Waterproof Bulkhead for Video Out (to surface)
· Spare Parts Kit (Extra O-Ring and Miscellaneous Hardware)
· 3 Years Warranty by Equinox; check
Camcorder’s control functions include:
· Power On / Off
· Record Start / Stop
· Zoom – Wide / Telephoto
· Autofocus / Manual switch
· ND [Natural Density] Filter 1 and 2
· Push button Autofocus Switch
· White Balance
· Push button iris
· Manual focus
· Iris dial
Note... Additional control functions can be added [contact us for info]
Key Features
· Depth rated to 200 feet / 60 Meters
· Durable & Strong - Housing body construction is rugged, durable PVC material, with stainless-steel hardware
· D-Ring on rear plate for easy hook up to a lanyard
· Close to natural color and view at about 33 feet / 10 meter
· BRS [Ballast Release System] for easy travel or if treble occurs on a dive... just pull the quick-release pin, slide the wing off, and your housing + camcorder floats to the surface of the water.
· Dimensions (LxWxH): 13 x 11 (Dia) x 14" (33 x 28 (Dia) x 36 cm)
· Weight: 55 lb / 25 kg
rushdance@gmail.com Hector.
i send pictures to INBOX
