Entry level mattebox and filter holder - $189
dakotapod
This is a pre announcement and will be ready to ship in about two weeks
[less if one of my suppliers steps up]
When ready to ship they will be able to be purchased right here on DVXuser.
I have designed and am manufacturing [and will soon be ready to ship] an aluminum mattebox with drop in filter holder and removable French flag.
Sorry for the crappy picture, it's all I have available right now. In about a week I will post some detailed photos.
I'm calling this an entry level unit as it's a low frills unit. But Very Usable. It's made from a super light weight but durable aluminum that does not require a support system. This unit weighs about 12 ounces! Comes with a removable French flag as well. Has the ability to hold 84mm filters [or P Series] Filters from Cokin, Tiffen, Hitech & Singh-Ray and others. I chose this filter size as it provides a huge range of filter options from $20 on the low end up to $180 on the high end. And tons in between. This give the user the option to experiment with using filters without the burden of laying out a ton of cash.
System mounts to front of DVX lens with stock sunshade removed. Aluminum adapter screws to filter threads and then matte box is snapped on. Installed and removed in seconds.
To keep the weight and cost down the filters themselves can't rotate, but the entire mattebox can be rotated for rotating grads if desired.
It will be best to use the full square filters to avoid vignetting [84mm x 84mm, 84mm x 100mm, 84mm x 120mm, etc] The square filters frames with round filters cause nasty vignetting.
This cannot be used with any wide angle lenses or 35 adapters unless lens has front threads but you would likely be unable to use filters. But could still be an effective sunshade. May cause vignetting depending on lens size up front.
This setup is shown on the DVX but can be used on any camera with a lens under 72mm with an optional adapter [an extra $15]
An example of the range of 84mm filters @ BH Photo - Cokin, Tiffen, Hitech & Singh-Ray...
http://www.bhphotovideo.com/bnh/controller/home?A=search&ci=4032&Q=&O=NavBar
Cokin has resins in the $20 up area. They need to be cared for very carefully as they can scratch easily but the upside is if you decide you don't like a filter it's no great loss to put it away and use little.
The higher end filters are far more scratch resistant, but are more pricey.
I have some organic glass filters coming from a supplier overseas and if they are a cool quality I will be able to offer them at a nice discount. [$20 for the more popular Grads and NDs]
I also have in development a 100mm holder [4x4] but it's very early in the mold process and will be coming from overseas and will certainly be months away if not much longer.
I will be initially rolling out a dozen units in approximately two weeks and production will continue from there.
Again, more pics and detailed info soon....
Awesome.
Looks fantastic.
I've been looking for a cheap, affordable, mattebox. This is cheaper then the cinetactics.
There is no vignetting?
Looks great. Just what I've needed. Will this require adapters for the HVX? Could it be used with rods? And it has one filter holder?
Justyn
Justyn
Holds 3 filters but I would be leery on stacking too many low end filters. 2 or 3 high end filters would be ok.
HVX - NO. lens is just too big for a 3 1/4" filter
Rods are not needed. Rod systems on the market may or may not work. Again, not needed so I will not be looking into rods.
Great timing Dakota!!! I just bought a Formatt...!
Thats a nice looking mattebox with a very nice price.
oops... I was going to make an early announcement a couple months ago, but I wanted to be 100% sure with suppliers [as I am now] - "Coming in 3 months" is not much use to anyone IMO...
AZsspvideo said:
Let me know when it's ready for sale.
Will do - As soon as they are ready to ship in 10 days or so there will be an announcement :thumbsup:
Nice - Great deal! So this connects to the DVX threads? Wouldn't that get a bit heavy with three filters? I just wouldn't want to stip my threads.
No worries at all - 2mm filters are light. Also, the box itself is feather light and the filters are on the lens side so there is no *down* weight issues at all. You are still looking at a fraction of the weight as a wide angle lens....
This unit is insanely light! :thumbsup:
Wow this looks nice for the price! Also have to commend you on waiting for supply readiness before throwing it up.
