End of my Test run and some Final thoughts...
been done before
I'd like to see you fit 2 dudes with swords in a shower
Wow, you didn't just write that.... You might need to have a talk with your girlfriend, or some special time..... :-P
Of course, maybe your just having a " Hard " day...........
LMAO...
Kholi when ur done cleaning up, you don't find the hoya duto is too soft shooting talent do ya or are you just using it for scenic shots? I'm just afraid it's gonna look like daytime TV
I just got the tiffen film look kit, I'm gonna try it out today before I send the D90 to it's new home.
Didn't use the Duto last night. I think it'll only be fore wides to help with aliasing.
I really, truly want a 1080/24P without pulldown from this camera. Not MJPEG, but AVC-HD @ 17mbps. A Fixed bitrate.
I would PAY for that update.
cheap canon camcorders can do 24Mbps so it's not a big ask for the GH1 which costs twice as much. Does something like the shot of the dude flipping off the tree break up much in 720p?
It takes more than that sort of scenario to break the 720/60. But the strange thing is that I did some 1080/24 Motion like that last night and for some reason I didn't see it get hit as much.
That's what made me decide that I really want a fixed bitrate and no pulldown.
On the most serious note, this camera is already on its way to being the new holy grail, I'll pay for the 1080/24 no pulldown and fixed bitrate in a heartbeat.
Does this mean you're ready to join the GH1 firmware upgrade campaign? :thumbsup:
X2
On another note, Kholi are you happy with the image on your LCD?...I'm getting kind of a brown shadowing on the trailing edges of objects on movement. Can be reduced when in standard film mode but it's eating at me a little. Tried it on another GH-1 and same deal. Of course it's more of an aesthetic thing but just seeing what your thoughts are.
I would just be happy if the 2:3 pulldown could be completely removed. At this time, there is no easy way to remove the pulldown without interlacing artifacts. I was going to import this camera for shooting an infomercial in a few days, but unless there is a way to fix this in post soon
MJPEG is an awful compression scheme. Very high bandwidth can mask a little. It is way inferior to H.264.
I disagree with DavidNJ on a lot, but in these statements above, he's not giving opinion, but stating facts. Well, "awful" is an opinion, if he'd rephrased it as "far less efficient" it would be stone cold fact.
c'mon panasonic 24p mjpeg with 20% more data per frame, it's not a big ask
Because you want your images to look worse? MJPEG is significantly less efficient than H.264, more than %20. There's a reason they only use it on the lower bandwidth images.
Remember, visual bandwidth is resolution X fps. MJPEG is tapped out at 720@30fps.
If they had chosen to go with the scheme you're suggesting for 1080/24p instead of AVCHD, you'd really be complaining looking at the results (even at a %20 higher bitrate.)
In all my pixel peeping, shooting at 1080/24fps, with the correct shutter, will produce a very high image quality, and a very filmic look.
A film camera shooting such a scene will have motion blur. And yet film cameras are used in action shots.
Why is it, in the digital realm, shooting with the same frame rate and shutter, which produces motion blur, causes people to complain that "the codec's breaking down"?
I believe this is an assumption born out of an ignorance of how codecs work. 17Mbps is not comparable to HDV bitrates, they are different types of video. 17Mbps is not a "low" bitrate. Motion blur is not a failure of the codec, its the result of a relatively long exposure time.
It is, in fact, exactly what you want in action sequences, if you want a film like look.
The 43Mbps codec of the 5D mk II is just a sign of canon's incompetance, or disintrest in making the 5D a real video camera. I think people are confusing the results of its full frame sensor and extraordinarily high bitrate to compensate for lack of CPU horsepower, as some sort of ideal to shoot for. Excluding the differences in sensor, the GH1 is delivering better video post compression at 17Mbps than the Canon.
Kay, you're probably right about the MJPEG. Dunno what's what there myself, but I need to ask you, Liza...
Have you EVER actually SHOT action before????
