End of my Test run and some Final thoughts...
I've now used Neoscene, Procoder 3, AE CS4 and tried a myriad of plugins on the PC, but anytime there is motion in 1080i mode, the codec runs out of steam. It honestly looks like a 3mb codec in motion rather than a 17mb codec. There's almost no reason to even try removing the pulldown, because the footage is unusable when there is any motion on the screen. Everything gets to be a big garbled mess
That might true true in some cases but not all.
http://www.vimeo.com/4720871
Yeah I noticed that. Thought it was just the computer but I checked it again here at work. It's funny because I couldn't tell with the girl walking in the beginning.
But anyways I thought the 24p in these cases looked good.
Just checked out your video, and there is definitely something wrong with the pull down. Check the background of the boats, they strobe quite a bit.
What computer platform are you using... Mac or PC? And most importantly, which decoder?
For me, There's nothing wrong. The video is clean. And for the record I'm using Windows 7 native AVCHD decoder, which is very good at rendering this codec.
Man...it's almost a sin on how Vimeo mucks up the footage. I suggest downloading it...it looks way clean with no noticible artifacts.
I tried Neoscene. Unfortunately it doesn't properly remove interlace residue. VoltaicHD + JES seems to be the only way that has worked without a hitch for me. I've got comparison stills between the two and just need to find a place to upload to share.
I would love to see that comparison. Perhaps you should send an email to the Cineform people too?
Have you had any luck outputting to prores without artifacts? Having to use AIC and grade my film in an 8bit palette is scary.
The panny fanboys aren't going to like what I'm about to say but this cam is becoming more of a headache than the D90 and I don't even have it yet.
The term: Fanboy is unecessary man. You're bouncing back and forth between forums spouting this and that over Pentax Ks and D90's, changing your mind in every other post, maybe you just need to take a moment and let things progress.
might be good for the actual writing stage of your film
Squig, I've had luck with Prores. My workflow is now ingest with VoltaicHD to AIC, and then remove pulldown with JES to prores. This works well.
I'm getting in touch with David at Cineform so hopefully he can figure this out. I'm hoping for a one click solution and not multiple generations.
Cool thx Isaac. Cineform sounds like a preferable codec to prores and I'm thinking I might just grade in photoshop or try colorista if apple don't get their act together with quicktime support for color.
relax Kholi I was just taking the piss man and it wasn't even directed at anyone in particular.
I get a bit restless when I'm cameraless and I hate relying on others to figure stuff out, I like to get my hands dirty.
I've now tried your method on a few clips and it works great. The good thing about this is you can ingest on some lower spec systems for logging etc. I tested this out on my old G4 mac mini, was a little slow obviously, but worked fine. outputs a clean image.
Too true! The stuff you did with the train looked great. I also had go at grading the footage of the girl, using Blender and I think this gives pretty good results.
http://vimeo.com/4745647
what is this interlace residue? neoscene was the only thing on PC that i've tried that removed pulldown perfectly.
edit: is this just a mac issue?
Hell Yeah to Isaac_B for figuring this all out.
Looks like it's going to be either a Cineform workflow or an Apple LandT to AIS > Pulldown.
Great work!
