Selling my Elements Micron 15mm dovetail/bridgeplate package with shim (for Sony F5/55) and detachable shoulder pad.
The package is solidly built with quality workmanship in design and machining. Everything included is still in excellent shape and working as it should. This setup is for 15mm rods and was used with the Arri MFF-1 follow focus and MMB-1 matte box. The entire package consists of:
1x ELEMENTS MICRON 15MM DOVETAIL
• Designed to be a scaled down version of the Arri dovetail for 17mm rods. This is shorter, thinner and lighter to accommodate 15mm rods
• Sturdy safety catches at both ends of the dovetail
• Provides quick, easy adjustment when needing to slide your camera forward or back for balance, focus, framing or other reasons
• Easy release of bridgeplate for immediate transition to handheld mode
1x ELEMENTS MICRON 15MM BRIDGEPLATE
• Should mount to all professional and/or prosumer camera models as well as quick release plates
• Locking knobs for rods and dovetail are easy and precise to use with solid hold
• Travels the length of the dovetail with no snagging
1x ELEMENTS MICRON SHOULDER PAD
• Shoulder pad is easily removed via a single bolt matching the majority of quick release plates
• Pad is able to stay mounted as long as you are using the bridgeplate. Even when mounted on a tripod or any fluid head. Easy transition to handheld by simply sliding the bridgeplate off of the dovetail and you're ready to go.
1x ELEMENTS MICRON SHIM FOR SONY F5/55
• This is used to provide the precision spacing to allow a matte box or follow focus to align vertically with the optical center of your lens(es)
ALL NECESSARY HARDWARE (15MM RODS NOT INCLUDED)
Asking $550.00 OBO. Available for pu in NYC area.
PayPal / Chase QuickPay only
