Element Technica for the F3
lennywood
Thanks to the good people at E.T., I was able to get my hands on an early version of their "bridge plate" for the F3, and I like it. Now, this is not the finished product, the shoulder pad is still being configured, but even without it, it felt pretty comfortable. For now, the plate is designed to be used with their Studio Hybrid Core, but that is not a great match, because it stabs you on the chest when you use the unit shoulder mounted. I am happy to say, they are working on a permanent solution that will be specifically designed for this particular unit.
I can't wait for them to get this baby complete, I know it is going to be a wonderful, relatively low cost, option for this camera.
For my set up I "frankensteined" it with the arms from the E.T. mantis, the rosette extensions from Birns and Sawyer, and to mount it on a sacthler tripod, i mickey moused something using Hot Rod and Sachtler parts. Not great, but I needed something to hold me until E.T. is ready for prime time. I also added the new Anton Bauer power solution for the F3, mounted on 15mm rods, thanks to E.T.'s great idea to add holes in the back of their bridge plate making it possible to attach a 15mm studio clamp on there.
Here are some photos of the contraption.
ps
One thing I forgot to add, I got the Small HD DP4EVF and I really like the quality of the image compared to what I had before (a first generation Cineroid). I have not played with the Zacuto, but this DP4EVF works great and feels solidly made and with high quality finish. BTW, I don't work for any of these people, "i tells it like I sees it."
This was alredy done six moths ago.And is more ellegant.And fits FS100 too.
http://www.smartassembly.ca/
that's great, so one option was made and no other company shall make other options? i don't see where you attach to a tripod, am i missing something? can you add 15 or 19mm studio rods to that unit? you can to the E.T. where are the 15mm rods in the back to that i can mount an unlimited amount of options? maybe it is not the end all be all solution after all.
Curious what arm or device you are using for your DP4-EVF? If you have an overhead photo or another photo that shows the arm placement that would be helpful.
...and the Anton Bauer cheese plate with 15mm rod supports which by the way, also looks nice.
Is there a link where to check it out? Price?
Did you need that extra green plate at bottom? Can you just put the Sachtler plate under it and not have two plates. Looking forward to finished product, any idea when.
sort of. i needed a little more separation so the rosettes could clear the top of the tripod and the camera could lock safely into place.
i will post more pictures in a little while, to show this from every possible angle.
as i understood it, in a few weeks this piece should be finished, with shoulder pad and all. but better call them to get the official response.
more detailed photos
