Steve Shovlar
DVXuser Sponsor
Phil Bloom recommended a shoulder support over on his blog, and doing a bit of research discovered it for sale on ebay at a bargain £29 inc postage!
I ordered it from the Chinese seller ( who has 99.9 feedback on over 2000 items) and it arrived here in the UK in less than a week. Excellent.
OK now I dind't expect much for the money. Certainly nothing high quality. But I was pleasently supprised. Its made of a very hard plastic and comes with straps.
So I tried to mount the EX 1 onto it and hit the first little snag. The screw comes out through the plate too much and needed to be be shortened. Five minutes and a hacksaw later it was job done.
No instructions come with it but it doesn't take any brain power to work how it goes together. There is a good quality adjustable strap which clips on and goes around the body for extra support, and the support is spring loaded so you adjust it to your size and tighten the screw to keep it at that size.
Tried it out and it completely solves the side to side imbalance of the EX1. With everything in place you can go completely hands free and let your body take the weight.
Now there is a small caveat which I am going to mention. You are placing a £4500 camera on a £29 piece of plastic from China. All that is supporting the camera is a screw supported by brittle plastic. And that is supported by a screw and some more plastic. If one of those gives way, it could happen in a split second and your camera and a piece of the shoulder brace could be smashing against the ground before you can react. This though is easily solveable.
Buy a small adjustable strap, run it through the handle of the EX1 and attach it to the clips on the bracket. If the impossible happened, the camera would just fall a foot or so and dangle without hitting the deck.
Here's one on ebay at the moment.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230225131012
Well worth getting.
Well worth getting.
