David G. Smith
Steak Knife Member
I had picked up a real inexpensive battery powered ring light and shot with it recently. I thought I would share my thoughts with using it. I only used it for photos, but I do want to use it for video.
The light that I got was the NEEWER® Macro Ring 48 LED Light.
http://www.amazon.com/NEEWER%C2%AE-Macro-Ring-LED-Light/dp/B0031AQ302/ref=sr_1_2?s=electronics&ie=UTF8&qid=1363551689&sr=1-2&keywords=NEEWER+48+LED+Ring+Light
It is powered by two AA batteries and I used it with the the 58mm lens mount ring on the 18-55mm f3.5-5.6 kit lens with my T2i. The lens mounting rings are metal and it came with six of them (49mm/52mm/55mm/58mm/62mm/67mm). Their construction is pretty solid and the 58mm ring fit on the lens with no issues. The light it self is all plastic, and kind of flimsy, about what you would expect for a $40.00 light. All in all, I like the light and plan on keeping it on my T2i from now on. I can;t stand the on camera flash, and this ring light is pretty good to replace it in many instances.
Here are some of the shots I took with it.
Here is a snap shot, taken in very low light conditions, of the producers of the gig I was doing.
Original shot:
and here is the shot with a little increase in exposure in post.
Shot, without the ring light:
Shot with the ring light:
I did find out that at the wide end, about 24mm or wider on the T21 you can see the ring light in the shots. Of course you can crop it out on a still.
Here is one of my favorite shots with the light:
All in all I like the light and for the price, it is another handy little tool to have around.
Thank you.
Original shot:
Thank you.
