Marshallarts
Let me start by saying I've never much liked the "video" look (i.e. 60i). In the 80's and 90's before I knew anything about 24p, pulldown, NTSC, etc., I, much like others here, could always tell when stock footage was inserted in my favorite TV sitcoms. You know, when they cut away to a shot of a helicopter or something and it goes from a 24p look to a 60i look. Also I hate pan-to-scan for this reason and that just dawned on me since it's probably due to sampling/ scan rate not being 24p. That faster frame rate look really jars the viewer out of a 24fps experience. Pan to scan could also potentially create other issues I guess since it would inherently violate motion blur created during 24p capture unless the scan is made with this in mind. This thread isn't about pan to scan however but I want to take my time asking this because this isn't a simple "video look" question. I really want to hear educated opinions here.
I originally began thinking about this when reading about Ansel Adams and the inverse focal length (reciprocal focal length) rule in 35mm still photography. In 35mm photography it is best advised one not shoot any subject (even a still subject) at any slower shutter speed than the inverse of the focal length of the lens you are using. Ex: If you are using a 60mm lens you should use a minimum shutter speed of at least 1/60 second (even if you use a tripod)! Ansel Adams stated through experimenting his minimum shutter speed for a normal 50mm lens is 1/250 second, even more extreme! This is all so to reduce to the point of eliminating blurring due to camera shake and achieving maximum sharpness (since after all that's why we have the expensive lenses).
The problem in motion picture is obviously at a 180 degree shutter shooting 24fps the shutter speed is locked at 1/48th second. Now I know you can change the shutter angel in film or shutter speed in video and I know how that in turn will also change the image (introduce strobing, etc.) so please don't reply with that, let's think deeper.
We all want a great image. But why do we bother with the expensive gear and difficult techniques when true still photographers methods to achieve sharpness far exceed motions pictures capabilities? One answer would be to increase frame rate of capture. If we shoot 50fps instead of 24fps we effectively get a safer shutter speed of 1/100 second allowing us to use up to a 100mm lens (in 35mm cinematography) according to the reciprocal focal length rule.
Then I realize this would bring us closer to the video look of 60i. I'm not talking interlaced or progressive, only frame rate here. I've been trying to find a way to produce an example of frame rate change from say 18fps to 100fps for purposes of being able to "see" this change. As far as I know this hasn't been done, though please tell me if it has.
I hate the 60i look but may come to appreciate it if I can see how 24fps can become 60fps. I would also be interested in experimenting shooting at this faster frame rate for purposes of getting a sharper image. Perhaps in the future the 24p standard will change when people begin to demand sharper images. Truth is 24fps does have awful motion blur issues (just hit pause on any DVD). In achieving a more life-like look as one sees with their eyes maybe a faster frame rate is needed.
