Editing using camera... more test results
EditingFX
*Finally* got around to testing multiple formats for the "edit & playback from camera" concept. For those that haven't heard, you can edit using clips on the 500 via USB and FCP. Then "push" the edit back to a card in the camera when done.
Great results.... DV25, DV50, DVCProHD 720 24p, DVCProHD 720 30p, and, yes, DVCProHD 1080i60. Tested using 30 second edit sequences, with effects & 3 channels audio output. This is no replacement for a fast RAID array with SCSI or FW800 interface, but for basic editing, it should be fine. Note the obvious limitations on space.... you can only use cards **in** the camera (no swapping), and space for the final edit output must also be available (though you could create a card image on the laptop, re-format one of the cards, and then copy the image to the card).
But thinking of ultra-fast run n' gun, followed by the fastest edit POSSIBLE ANYWHERE, then SDI-HD/SD output, well..... WOW!
Oh yeah, Raylight is mandatory for this exercise.
