Ok, here's the situation...
All day corporate job shooting with 2 HPX500's simultaneously.
Each camera went through about 7-16GB cards rendering 116 clips across all cards.
For what its worth, I work in CS3 Production Studio.
Using P2CMS, I exported each cameras clips into folders labeled Cam1 and Cam2.
So far, so good...
Now, I understand the naming convention assigned by the camera as being 001xx, 002xx, 003xx, and so on, which is fine, but when I dumped the contents of all of the cards into only 2 folders, I realize that I now have 7-001xx, 002xx, and you get the picture... with no distinguishing component other than the time and date stamp.
So in rethinking my workflow, I need to sort by time and date, and then rename the clips 001C1, 002C1, 003C1, and so on.
My question is, if I rename the clips using, say Adobe Bridge, will that mess up anything as it relates to all of those other folders within the Contents folder?
Also, I noticed when I bring the clips into PPro, that I get all 4 audio tracks even though there is only audio on one track.
Is there any way to bring in only the tracks with audio?
Thanks,
Brad
So far, so good...
Thanks,
Brad
