edible raw meat
You may be able to get away with chopped up roast beef like you buy in the little packages.
-Nate
You could probably dye some corse oatmeal, might pass for raw ground beef if you get the color right (and its not a macro shot).
If you go to the right butcher it could be actual ground beef.
You could try using a pizza cutter to cut slices of Tofurkey Bacon. It can be eaten raw but also has a reddish look even when cooked.
Just saw this... I am probably to late to help, but if you do a search for MEAT WHEAT or SEITAN you might find something usefull.
How about spicy tuna sushi... same color at least and messy gross if your looking for that.
