Willis Chung
DVXuser Sponsor
thanks for letting me know that, im new to 35mm adapter, going to barely receive my first (LEX) next thursday, going with Zeiss Contax mount on E0S adaptor, anybody doing that setup?
I do. But have to make my own set up ring.
The EOS adapter is not very steady on the Letusadapter. So you can't use a FF or handle the focus ring without shaking... One of my lenses went down on the ground...
Ditto Philip,
There must be some some cheap shop that specializes in the Nikon mounts for inexpensive 35mm adapter makers. I won't go into to details but if it holds in the lens and maintains back focus you're doing OK.
There's play within my EOS mount from Letus. The lens actually wobbles a bit which makes it unusable to me. Luckily my main mount is OCT 19. Aaron at Letus said they're looking into the issue.
I didn't realise there was a contax mount. Their Nikon Zeiss glass is stunning as you probably know.
