SOLD Edelkrone -- THE NEW DOUBLE SHOULDER PAD
Status
Not open for further replies.
Max Diesel
I'm selling my Edelkrone Dual Shoulder Pad.
Cost on Edelkrone.com with shipping is 1460$ + Customs and Tax which gave a total of over 1650$
Selling for 1050 USD + Shipping + Paypal Fees. Which saves you over 30% :2vrolijk_08:
The items is basally new with minor scuffs on the anodized paint due to the way it opens, slides and closes. These are inevitable.
Comes with Box, and extra pads.
Item is located in Canada, there are many shipping options depending on how you'd like to receive it, I can also declare a much lower value on shipment.
Thank you.
Item Description:
THE REAL BALANCE IS HERE
It's easier to carry with both shoulders
  • The New Double Shoulder Pad can be transformed from single shoulder mount to double shoulder mount in a few seconds.
  • Distributes the weight evenly on both shoulders.
  • Shifts counterbalance weights to the opposite side in double shoulder mount mode to create a cross-balancing system.
  • Adds delivers even better balancing by extending the weights further back.
  • Ideal for carrying the camera load on shoulders for longer durations.
  • Adjustments are instant and tool free.
  • Drastically increases the amount of shooting durations, maximizes stability of the shots, helps achieving smoother pans, prevents back pain and/or injuries.
  • The counterbalance weight system can be extended further back for the best balancing solution in the industry.
  • Several 1/4 and 3/8 inch holes on the back of the shoulder pad to provide additional accessory mounting options.
  • Sony IDX V-Mount and Anton Bauer battery plates can be directly mounted on back of the shoulder pad (in order to use battery plates in combination with stainless steel counterbalance weights, cheese plate is required).
  • Dimensions 28 x 13 x 9 cm
  • Weight 1.856 kg
  • Materials Used Aluminum & Plastic
Status
