SOLD Edelkrone SliderPlus X (SliderPlus Pro Compact) Slider + Steady Module BUNDLE
Status
Not open for further replies.
neweditor
Hello, for sale is an: Edelkrone SliderPlus X (SliderPlus Pro Compact) Slider + Steady Module BUNDLE
Like-new condition, meticulously looked after, superb smoothness. This is an exceptional deal, as this is in virtually mint condition and perfect working order and was purchased for double the asking price.
The inclusion of the Steady Module lets you get motion-control-like smoothness and precision when paired with the rubber belt (swaps out in seconds due to the magnetic belts in this slider)
This slider is equivalent to Edelkrone's currently listed renamed slider "SliderPlus Pro (Compact)"
Please keep in mind, this is Edelkrone's "elite" brand of sliders and has some significant differences between the cheaper ones you see:
- It has interchangeable magnetic silk and rubber belts (as opposed to screw-ins/outs) for swapping or adjusting in mere seconds based on the application you're going for (motion control vs. manual, etc)
- It has an attachment ring on the bottom of the slider so you can mount it at the exact angle you're going for in seconds, as opposed to having to spin it around and turn the tripod itself to accommodate the slider.
This allows for precise setup of the exact type of slide you want and makes working with it in the field much quicker
- It has sturdy mechanized foldable feet built-in to the slider as opposed to having to be connected/disconnected/micromanaged
- Build, smoothness of slide, and weight capacity are significantly improved
- It is incredibly portable for the specs it has
THIS LISTING INCLUDES:
- Edelkrone SliderPlus X Camera Slider (Short) - Equivalent to the currently renamed SliderPlus Pro (Compact) Slider
- Edelkrone Steady Module
- Steady Module Thumb Screws
- Magnetic silk belts
- Magnetic rubber belts
- Foldable mechanized/rubber wheels on the bottom of the slider for use on any flat surface
- Edelkrone Original box with foam-fitting padding
- Allen Wrench Set
- Edelkrone Original Slider Documentation
- Edelkrone Original Steady Module Documentation
- Extra Replacement rubber belt
If you have any questions, please feel free to ask.
Ships out SAME or NEXT business day.
$499 Shipped. I will also cover all PayPal fees.
Pictures here: https://drive.google.com/open?id=1KFLfzW2A_mN1dvYkZ1-sOHxgRRCxhx00
Status
