Easiest and cheapest path to component?
wpd108
I'm using my AF-100 as a source for a switcher/encoder (the Telecaster 40) that accepts HD Component, SD Component, Y/C or Composite....
Would the yellow RCA video out be a solution to feed the input to Composite? We are not streaming in HD.
At this point, I would prefer not to spend the $300 on an SDI to analog component converter.
Thanks for suggestions.
Yup, that's how it works. I'm guessing you meant Tricaster 40? If not, what's the company name of the product, because I can't find anything on it. Will you be using CAT5 cable with baluns to convert the signal?
