I just noticed that there's a new firmware update:
Ver. 1.84-
Improvements
1. On rare occasions, the operation of REC button on the unit or a wired remote control may no longer have any effect. This problem is fixed.
2. If the card is ejected from the main slot during the simultaneous recording, the recording in the sub-slot stops 10 hours after the start of recording. The indication shows the same as during recording, and the operations of REC button are refused. This problem is fixed.
3. LCD may not show anything when the camera is booted up. This problem is fixed.
4. A very few SD cards may have a write error. This problem is fixed.
5. If the network address is changed when WIRELESS SETUP is set to [DIRECT] and DHCP is set to [SERVER], it sometimes made the camera impossible to connect to the iPad. This problem is fixed.
6. If SET button is operated on AG-ROP app, the count number of “Jog Dial” item of Hour Meter is increased. This problem is fixed.
7. When 480i squeeze output is carried out, an image quality may be the slight deterioration. This problem is fixed. (Recording signals do not have any problem, only output signals have this problem.)
Conditions:SDI/AVOUT output of playback on MOV/MP4/AVCHD
Input: 1920x1080i/1440x1080i/720x480i
Output: Squeeze output of 720x480i (down-conversion)
Ver. 1.84-
Improvements
