Hey Guy's, Has anyone played around or tested the Auto-Focus speeds and sensitivity on the DVX200, what are the trade offs, and how it works with certain subjects? :-Happy(DBG):
AF Speed is simple -- it's how fast the autofocus system focuses. Experiment with it, you'll see -- the fastest speed will snap things into focus, the slowest speed causes the focus motors to respond very gradually. On the fastest speed, it can be a bit "twitchy" if anything changes in the frame. On the slowest speed it might be more graceful in its transitions, but -- if your object is moving fast, the slowest speed might not be able to catch up to it adequately, where a faster speed would do better.
AF Sensitivity is basically a delay before the autofocus thinks it needs to refocus. The more sensitive you set it, the quicker it will be to respond. Two examples: if you're videoing a kid on a swing, swinging towards you and away from you, you'd want the sensitivity at its highest so the autofocus can track the kid accurately. On the other hand, if you're filming a stand-up interview and someone walks between the camera and the subject, you'd want the sensitivity to be on its lowest, so the autofocus wouldn't hop immediately to the interloper and then leap back to the interview subject; instead you'd want the autofocus to "stick" on your subject. So if you set the sensitivity low, it'll be "stickier" and less resistant to start hunting for a new focus point. It works sort of like a delay; the autofocus system may think "ooh, we're out of focus now" but the delay says "eh, don't worry about it, don't go hopping over like a rabbit on adderall, stay put. If we're still out of focus a second from now, then you should refocus."
So -- high sensitivity means excellent tracking on a moving object. Low sensitivity means stable focus without it snapping around or getting distracted.
filming theatre shows with lots of light on stage and the autofocus goes regulary out of focus. So when it's in focus it just starts hunting for a very short time and goes back in focus. Even when there is no action on stage. And sometimes it goes fully out of focus so I have to zoom out and zoom in otherwise it stays out of focus I think. I had this problem with the default settings for speed and sensivity and with these setting at highest. I have firmware 1.83
I have the luck a have a second fixed camera that covers this problem. So I can noramlly use this wide shot when this happens. Is this a normal behaviour with this camcorder?
I made a short compilation about the issues I had with last theatre show (I muted the audio)
https://www.youtube.com/watch?v=NtgqB8m-0Uk
thx Larry for your advice. I don't understand what you are saying. You shoot in manual focus and sometimes you push auto? Write down but I'm always in the dark (like you I guess) when filming.
It's already difficult to find the buttons when standing in the dark for filming.
regarding: "I don't understand what you are saying. You shoot in manual focus and sometimes you push auto?"
Even though you are in manual, the button called "focus assist" overrides manual and gives you a momentary autofocus on the subject. The camera remains in manual mode. The focus assist button is a momentary focus button that does not change your focus mode to auto. As far as seeing it in the dark, maybe a penlight or a clamp-on gooseneck led light for your controls.
Larry and Sneakle,
I have read messages before I did my next theatre this weekend. So switch to manual focus and focus assist and "push auto". this works great! It's easier to see with peaking to see if it's in focus or not. Because I wear glasses it's very difficult to use the viewfinder.
But this theatre show was with 30 actors and the lightning was not bright (the autofocus was better this time, not so much hunting). Mostly I did used autofocus but sometimes there were scenes with only 2-3 persons talking so I had time to switch to manual and push auto.
That was a great tip you gave me here! I also assigned the push auto to another button.
Are you using an external monitor also?
