You can find the new update here:
http://eww.pass.panasonic.co.jp/pro-av/support/content/download/EN/ep2main/soft/upgdvx200_e.htm
These are the changes:
Ver. 1.65-
Improvement
Ver. 1.65-
Improvement
- Improvement of V-Log L gradation (more distinct gradations at low luminance areas)
- Improvement of color reproduction of recorded still images
- Adjusted values of Gain are maintained even after being rebooted.
- Addition of a negative Gain* adjustment
*The value between -6dB and -1dB or ISO250 and ISO400
[EXTENDED SENSITIVITY] menu added. - Improvement of operability
- Addition of a sign showing that Shutter is set to “Auto” “A-SHTR + numeral (shutter speed)”
- Assignment of USER SW to AWB button on the front is enabled.
- Assignment of Focus Assist function to USER SW is enabled with EXPAND and PEAKING separated.
- Mode1 (EXPAND/PEAKING/BOTH) ON/OFF
- Mode2 (EXPAND/PEAKING) ON/OFF - Addition of functions that can be assigned to USER SW
"PUSH AUTO","SLOT SEL”,"AWB" - The fastest mode is added to Focus Transition function.
- (AG-DVX200MC Model Only)
1. (EVF/LCD Output Destination Switchover: Default setting is changed to LCD.)
2. (High sensitivity mode to default setting )
