DVX100B with Letus FE - Am I using them correctly?
Adrius
I just picked up a used Letus FE from a fellow user on the forum and am not totally confident on how to setup the settings on my DVX100B to be used properly with my Letus FE.
1. What I've done after mounting it on the DVX and rails, is I turn on the adapter, then turn on the camera. Zoom in all the way, set it to auto iris, auto focus, and off I go. Is this the best way to do things? I'm not sure about the auto focusing. I ended up on auto focus because I couldn't really find a spot to get a clear image so I just set it to auto focus. I'm wondering if there is a more proper way of doing it like locking the focus somehow?
2. I'm also having a problem with my mounted panasonic shotgun mic picking up the low humming of the adapter, is this normal?
3. I've been ready Barry's book and am at the part about strobing and panning times. It says on a z99 it takes 120 seconds to pan 90 degrees. When using the Letus you have to be zoomed in all the way, does the the 120 second guideline still apply?
Thanks guys!
Adrian
Here is the set up:
1.)Mount adapter and lens
2.) with the LETUS OFF zoom your 100b in on the Ground Glass until it fills the frame. Focus on the grain pattern of the ground glass. Stop down your 35mm lens to help the grain be more visible.
I would not recommend auto iris or auto focus with the adapter
The hum is common on a set up like this.
Thanks for the quick reply. I've changed the format of my post so sorry if the numbers don't match up anymore.
I'll definitely try what you suggested, I had no idea that was the procedure!
Is there a way to lock the focus so that when I move the focus ring it won't change?
