Hi,
Im thinking of buyin DVX100B cam and I heard about "the color saturation pattern" problem. If I got it right, it will show those blocks on red (on blue and green also?) and you cant fix it by turning saturation low in camera?
Is this very visible? And does this happens everytime when there is some bright red?
If the footage is shown on TV, can those blocks be seen in TV also?
Is DVX100b's video quality 'better' than GL2's?
(I had GL2 and I wasnt satisfied how it showed up all colors. Colors were kind of 'candy looking' and green was bright green even when saturation was turned down etc.. Does DVX100b produce more 'natural' looking colors than GL2?)
Is DVX100b's progressive shooting mode better than the GL2's 25p?
Does DVX100b make red, green and blue look more saturated than other colors?
Does DVX100b make easily noise to video? (For example in to shadows or some other dark areas)
How does the "film look" actually appears in video when its normally shooted on DVX100 (25p or 50i)? Is it only the 24p-25p that makes it, or does the camera's colors and other things create the look too?
(Are those gamma cine effects 'cheap looking' film effects?)
Is there any bad things in DVX100b that i should know before i buy it?
Is there any uncompressed clips somewhere that have been filmed on DVX100b?
Thanks if someone could answer to my questions
