ronfromkwon
Inspired by the roller-coaster thread, a few comments and questions about time-lapse in general and the DVX100a intervalometer in particular.
First of all, I suppose it depends on the subject and how long you need to record the time-lapse sequence for to decide whether to use the DVX or a still camera...
Up to now I have recorded
What I found was:
Any thoughts/experience on using the DVX like this?
- a cabin build (2 days) and painting (1 day)
- other construction events (few hours)
- events with lots of people
- clouds and sunsets
What I found was:
- maximum frame rate of 1 every 2 mins is ok for several hours, but not so good for a couple of hours.
- need to get the focus right!
- manual exposure is OK as long as the light level doesn't change too much - but need to allow some latitude particularly if you set up outdoors early in the morning before the day gets too bright.
- Because of the high res, you can do pan/zoom in post quite easily
- motion blur and reducing the frame rate in post helped.
- Although a time-lapse sequence, unlike the still camera you get at least a dozen frames each time - and sound capture is interesting. This means you get a short burst of activity then a jump
- Capture treats it as a continuous clip (for which I'm grateful, although I'm not sure what is going on with the time code)
- Pan/Zoom - not tried it, but I guess that motorised drives will be better than manual?
- motion blur and reduced frame rate still help, but not so much
