This article seems to say so:
http://www.adamwilt.com/24p/index.html#The_chroma-patterning_problem
I do a LOT of greenscreening with a pretty bad set up--and no I can't make it better, but using Keylight I've been able to get great (or good enough) results as long as I've been using a decent camera. For instance, with a GL2 in frame mode I'd pull a fine matte, but with a digital 8, the scene was a total mess...not even a prayer of salvaging the footage.
I've heard that the DVX100 has bad low light performance (especially in progressive mode, which I'd be shooting in), and the chroma patterning seems to be an even worse issue. On top of the compression that's inherent with DV footage, these issues would seem to add up to an inability to chroma key except in the best possible conditions, which I do not have access to.
Should I look elsewhere (GL2, perhaps?) for chroma keying or is it possible to get good results with a DVX100? If it is, what settings should I use (I'd be shooting in 24p mode regardless, but film-like color correction could be done in post, so I could shoot with boosted saturation if necessary.)
Thanks in advance for your help! I'm new here, so bear with me if I ask stupid questions.
