dvx100 vs hvx200 filter adaptor ring?
rstorm
Could someone be so kind as to tell me if the dvx100 and hvx200 use the same size filter adaptor ring? i want to try and make an Ed35 adaptor but need to know if i can use the same 72mm filter adaptor. if anyone can help it will be greatly appreciated. thanks!
the dvx uses 72mm and the hvx uses 82mm unless there is some step down ring you need a ring for each. one 72mm and one 82mm.
i did see on the hvx lense the 82mm printed on it. since i am new to these things i was not sure if that was the measurement i should be paying attention to. thanks again for clearing that up. now i can proceed!!!
