Kindredmachine
It seems that you can't have the "input 1" audio record to "channel 2" while filming - in which I currently have a Panasonic MC200 mic plugged into. Does that mean any audio source coming in from "input 1" is basically recorded in mono ONLY to "channel 1" and has to be duplicated over to the right channel in post-production to simulate stereo audio?
If that's the case, could someone shed some light onto why audio "input 1" can only be recorded onto the (left) channel 1 audio and why someone would use this option instead of just using input 2 where you can record simultaniously to channel 1 (left) and 2 (right)? Do people just use "input 1" as the main (ideal) audio and then use a secondary audio input to record onto channel 2 for a backup (or soft) audio track? It's all a little confusing to me.
I just started using the DVX for filming so the audio options are very different from what I'm use to... just trying to figure it all out.. the right way...
Any advice or info would be highly appreciated.
Thank you!!
Thank you!!
