dvx100 PAL out of sync problem. HELP !!
Pop
Hi guys,
I have an original PAL DVX100 of 2003.
Few months ago editing a live concert, shooted with my camera (interlaced mode) I have noticed a 2 frame out of sync audio problem.
Now I am editing a new video and I see the same problem again.
I have done some tests in interlaced and progressive mode and the result is always the same: 2 frame out of sync. :cry:
What do u think ?
Yep. That's what happens. They fixed the sync issue in the 100A.
You shouldn't be seeing 2 frames in interlaced, but yes, you will see two frames sync offset in progressive.
I think FCP includes an option for delaying the audio 2 frames when capturing, to correct this issue. In other editors you just disconnect the audio and slide it over 2 frames and then reconnect it.
But it's a known issue, all original-model DVX100 cameras have it.
I thought It is only an NTSC progressive problem.
Not Interlaced and PAL !!!
What do u think?
:shocked:
