we're planning to use (1) dvx100a and (2) dvx100 cameras for scenes in a gymnasium with large crowds. what are the technical minefields of using the two versions of the dvx we should be wary of? tks.
Yes, heed the words of both! I just did some extensive side-by-sides for the DVD, and like a fool I set them on preset white balance, and the result is footage that does not mix well at all!
I'd previously matched the cameras using manual white balance, and you can get them *extremely close* -- but don't use the presets or your footage will not match.
I hear that the 100 does not have the true electronic “squeeze” setting that was ADDED with the 100A. Is this correct? If so, it's a big difference and would seem adviseable to rent another 100A if we use the electronic squeeze.
[quote author=Jim Brennan link=board=Events;num=1098109503;start=0#5 date=10/18/04 at 13:27:30]Interesting thread. It makes me wonder if I don't need to white balance after each lighting set up. I never rely on the manual settings.[/quote]
Probably. And, since it only takes a few seconds, it won't hurt even if not necessary.
[quote author=gtb link=board=Events;num=1098109503;start=0#6 date=10/19/04 at 05:28:45]I hear that the 100 does not have the true electronic “squeeze” setting that was ADDED with the 100A. Is this correct? If so, it's a big difference and would seem adviseable to rent another 100A if we use the electronic squeeze. [/quote]
If you're planning on shooting in squeeze mode, then yes you should get another 100A, because the 100 does not have squeeze mode.
