Here is some info (from Barry Green's DVX Book) that I think will be of use to the DVX community. The DVX100(A)(B) can be connected via Firewire to another (cheap) camcorder and use the second camera as a slave unit. This has a few important benefits:
The slave camera can be used to do all the recording for the DVX without a tape being present in the DVX's internal drive, thus eliminating head wear on the DVX.
The slave and the DVX can both record at the same time to make back-up tapes and to help guard against the occasional dropouts.
The Dvx and slave can be programmed to record sequentially so that recording time can be extended indefinitely without the loss of a single frame of footage.
Here's how to do it:
1. Connect a slave camcorder to the DVX via Firewire.
2. Go into the menu and select OTHER FUNCTIONS.
3. Select DV CONTROL
The options are:
OFF
EXT
BOTH
CHAIN
OFF: This is the default mode. This is the DVX's normal operating mode. In this mode, when connected to a slave camera via Firewire, anything the DVX sees, the slave sees, whether the DVX is recording or not. By pressing the record button on the slave, you can record whatever the DVX sees without the DVX recording.
EXT: In this mode, the DVX does not record to its internal tape drive at all. Instead, the data is sent to the slave and the slave does the recording with no loss of quality. Just set the slave to VCR mode just as you would when using it as a capture camera. Then, just record as usual (press "Record" on the DVX) and the slave does the work without a tape even being in the DVX. So, no head wear on the DVX!
BOTH: This is self-explanatory. When set to BOTH, both cameras are recording what the DVX sees. Just press "Record" on the DVX and both cameras record at the same time. Handy for making instant back-up tapes.
CHAIN: In this mode continuous, nonstop recording is possible. Put tapes in both cameras, set the slave to VCR mode, and start shooting. Press "Record" on the DVX and the DVX uses its own, internal tape first. When it is almost full, the DVX turns on the slave to continue recording. While the slave is recording, you can swap out the first tape so that recording continues, uninterrupted, when the slave's tape is full.
I hope this info is of some use.
The options are:
OFF
EXT
BOTH
CHAIN
