DVX and DV extraction scene problem in Avid
MikeH
In past projects I used DVX100 for filming and then editied on Avid 4.6 Xpro.
After setting the avid to automatic DV extraction scenes it worked with out a problem in the Avid.
In a new project I tried to do the same workflow but Avid did not "cut" the subclips as it did in the past. ( not automaticaly nor manualy from Bin menu).
I used an old cassette material and it worked - so my esumption is that Avid is ok , somthing is defrent with the DVX setting that does not aloow later the Avid to perform as in the past.
I set all the setup menues to the original factory sets and yet it does not work as in the past.
Has some one an idea what sould be done in order to get the option of subclips cutting again ?
Mikel
