DVX 100A vs. DVX100A (E)
  • Start date Start date
G
Guest
Guest
Scott Billups at www.pixelmonger.com says that if you live in the USA and have the oppertunity to buy and shoot PAL, do it. I'm wondering if anyone has considered or even checked the difference in picture quality between the NTSC and PAL versions of the DVX camera?
Re: DVX 100A vs. DVX100A (E)
Here is the deal. i havn't read Scott's book, or gone to one of his lectures, but there is only one reason why one would shoot PAL over NTSC, in NTSC land, DVX or otherwise. If your whole intent with the camera, meaning, everything that you shoot will be transfered to 35mm film, and I mean everything, not just on the weekends ;D then go ahead and get a Pal camera and shoot PAL. YOu have about a 20% resolution boost over NTSC. NOw if you even have a tiny incling that not everything you will be shooting with the camera will be transfered straight to film, and you really want to make some money with your camera, go with NTSC. It will save you hours and hours of headache's over trying to convert your footage and blah blah blah. Don't do it! in fact, why anyone would buy a "mini-DV" camera, who's sole intent in life is to finish in "film" is far beyond me. Shoot film people, if that is all you want to do. You think you will be saving money, but in actuality, this is what will happen. YOu buy a DVX100 PAL because you want to go to film. You shoot and edit your 15 min feature. YOu go to transfer to film, "how much do you want per min" $300?????? holy crapola!!!!!" lets see 15x300, $4,500. So you get your film "congratulations, congratulations," and it does quite well at your local movie theater. "good job" :) NOw you want to go onto your next feature, but your whole budget was blown on the 4500 for the film transfer, not to mention the camera. NO problem, DV is cheap, so you shoot it, comes out looking fabulous. People want to see it, "OK!!!!"whoopieee." YOu decide you want to make a simple little DVD. Well, your next feature is 18 min long, and you edit it all in PAL, you, didn't do any NTSC monitor corrections, becuase there is no program that will allow you to do it, so you did it on your computer monitor. Next you go to render out your project so that it will be NTSC compliant. YOu set your settings and press Render and wait for the little dialog box to tell you how long it will take. . . . And wait. . . and wait some more . . . and 27.5hrs later you have your file, whooopie. You press play, and it starts going, the credits go by, and then your main character comes on screen (he's a cowboy) and starts to move around as he gunfights his first villan at age 8. You notice these really large artifacting blocks whenever there is lots of movent. "what the hell!" you demand (not ask). To make things worse there seem to be interlacing artifacts in your beautiful 24"progressive" footage. "what is up?" you now ask demandingly. :-X So you look online for some software that can convert your PAL footage to NTSC. There goes another $2000 buckaroonies. You finally end up with your DVD, but since you didn't color correct on an NTSC monitor, the colors are not at all how you had pictured them, and you are out about 1 weeks worth of time and another $2000. You decide that since you now have all the stuff to edit your PAL footage and go to DVD (your only option BTW besides the computer monitor) that you won't be doing any more film transfers because frankly, there isn't the budget, or even really the need (with the DVx) to get the look you were after. While if you were an NTSC user, you would have totally surpassed all of that hassle with viewing your stuff on a TV and you could still go to film, have money left over for an animorphic adapter and match the resolution of the PAL camera that you shot with in Squeeze mode, because you didn't have the animorphic adapter for the PAL camera, the camera costs more by itself then the NTSC version as well. So there are your options, choose wisely, and if you sole intent is to end up with film, there are lots of cheap 16mm cameras out there that would save you lots of time and money, as well as shooting 35mm itself. IT really isn't so bad and scary after all.
Man, did I write all that for jsut one post? YOu can tell it's a lazy saturday afternoon.
Hi David, I am with you on this one.
Why would you buy a PAL camera if you are in a NTSC land? Just because of the 20% resolution?
I don't see much difference between the two cameras. They almost look the same too me.
Just stick to where you are. If you are in PAL land, then go PAL, if you are in NTSC, go NTSC.
All the best
Fidel.
