DVRACK HD in Native Mode
Nathan Beaman
Anyone figured out a way to use DVRACK HD with the HVX200 in any of the native modes since the firewire output is disabled in native mode. Using DVRACK with Bootcamp on a 17" MBP - so I'm already dancing with destiny.
In native mode, you can't use any software or hardware that reads from the DV port because as you noted, the HVX doesn't output anything in native mode.
However, DV Rack 2.0 HD will do pulldown automatically and remove duplicate frames. The disk space requirements on your computer are the same as they would be if you could record in native mode.
