I have a few questions about DVD Architect 6.0 that should be relatively easy but I have not been able to find the answer to.
1.) Is there a way to adjust the volume on a pages background music?
Audio is easy to drop in there, it's drag and drop, but is there a way to adjust the volume on it? Or is it simply set once the audio is in there and there's nothing you can do to it volume wise?
2.) Is there a way to start the pages audio track later in the track? For instance if the .wav file that has been dropped in there is silent for the first 3 seconds of the file, can you do something to tell Architect to start it later? I've messed around with trying to start the loop point later, and moving the green marker/flag/bar thing at the beginning of the audio track over to where I want the audio to start, but when I do that and preview it, it's not the audio that is effected, it's the text on the page. Any text on the page disappears until it reaches the indicated time marked used with the green flag/marker thing. The audio still starts at the beginning.
3.) Since I was unable to find answers for 1 & 2, I decided it would just be faster to edit the audio file myself in Sony Vegas 13 Pro - So I dropped the .wav file in question in Vegas - I adjusted the audio and cropped the beginning of said audio and rendered it as a .wav file. I then attempted to replace the old audio with this new .wav file, but DVD Architect wouldn't accept it. When I try, I get an error message saying "The selected file is not of the required type" - Which baffles me because it's a .wav file. I tried rendering it as a .wav with a few different options(16bit & 32bit as opposed to default) but it doesn't work. Any other .wav file I point it to will work, but these new adjusted audios that I render as .wav using Vegas, will simply not be accepted by DVD Architect.
I appreciate any help on any of this. I've spent hours scouring message boards, doing web searches and looking for tutorials that would address any of this but can't find anything.
Thanks in advance!
Thanks in advance!
