I shot a project yesterday on a Panasonic HPX300, DVCPro50 anamorphic. Imported everything today through Log and Transfer in FCP 6.0.5. Footage plays and looks great in FCP.
If I open one of the captured clips in QuickTime, however, it seems to be reading the pixel aspect ratio incorrectly and displays them as 1026x480 (a frame aspect ratio of 2.14:1) rather than the correct 853x480 for 16:9. If I bring them into After Effects, they have the same problem, except I can use Interpret Footage to correct it manually from the 1.46 it reads to the 1.21 AR it should be.
In the FCP browser, the clips are listed as NTSC - CCIR 601 pixel AR with Anamorphic checked. After Effects reads the files as D1/DV PAL Widescreen (1.46). I've never cut PAL footage in FCP, and no settings appear to be set to PAL.
This happened on a previous project, but I was doing the post so I could fix it myself. This time, I have to hand the raw QuickTime footage to the client and I'm afraid of dealing with the complaints that everything is stretched. Has anyone encountered this problem before, and if so, is there a way I can batch process (or recapture) the footage to apply the correct pixel aspect ratio (without re-encoding/losing a generation)?
Thanks,
Max
Thanks,
Max
