DVCPRO-HD Licensing Help
David Newman
This is message for anyone how can introduce me to the right contacts at Panasonic. In the past I have vented my frustrations will the lack of response to our enquires for licensing the DVCPRO-HD SDK from Panasonic. This maybe we have pursued the wrong department, so I'm looking to amend this. CineForm is in an excellent position to add HXV200 support to a wide range of PC applications and we already have HD tools for Premiere Pro, After Effects and Sony Vegas. All we need is a DVCPRO-HD decoder core (no encoder is needed) to get started, as we already have MXF tools and experience. So to Panasonic contacts, please consider CineForm a friend not a foe, as we in the business to support for HD and film formats across a wide range of PC applications, and we looking forward to supporting the HXV200.
Thank you,
David Newman
CTO, CineForm
www.cineform.com
P.S. For my direct contact information please was the Private Message feature of this forum.
Anders,
Yes that is true, unfortunately it is time to market issue. Plus Panasonic is the main expert in DVCPRO-HD, so starting from their optimized reference code helps everyone -- a quality codec that is already tested.
David Newman
CTO, CineForm
www.cineform.com
Probably would go over easier if you guys didn't concoct artificial tests that attempt to discredit DVCPRO-HD at every turn, and try to make a business case for your software on DVCPRO-HD's back. Like I said before, it's kind of bold to punch someone in the nose, and then expect them to help you.
But, who you want to talk to is probably Phil Livingston; if he isn't the right guy he can definitely get you to the right people. He's in charge of the P2 Partners program. I met him at NAB, a wonderful guy. I don't know if he does codec licensing but he definitely will know who to put you in contact with.
The competitive codec quality analyses we have done aren't kind to HDV also, yet we have enhanced the workflow for HDV cameras Canon, JVC and Sony, those companies don't feel as if their noses are bloodied (instead they enjoy the increase in camera sales.) Competitive comparisons are a common business strategy that Panasonic themselves also exploit to their best advantage -- as they should. Yet in our quality test for the various formats we never say that they are bad for acquisition, they are in fact both excellent. Our business is mostly post-production tools, and that is an area that we can help Panasonic. We're asking for no favors, just normal business discussions. I hope Panasonic can see the benefit of HVX200 support under Premiere Pro and Vegas, which CineForm can release way in advance of Adobe and Sony.
How may we contact Phil Livingston? Do you know which office he is in?
David Newman
CTO, CineForm
www.cineform.com
Fair comparisons I have no problem with. Repeatedly stretching and shrinking the image in order to exaggerate the differences, in an unrealistic and non-real-world workflow -- well, that seems to be something else entirely. I for one don't think that the comparison you posted is in any way fair, nor is it realistic, nor is it accurate. It's exploitative to an excessive degree.
Note: I'm not saying that CFHD is a bad codec or anything, I'm certain that there are things it does better than DVCPRO-HD. I just don't think that the way you've presented the two is legit, that's all. And I could certainly understand why they'd be in no rush to help in a circumstance like that. But hey, it's your business, conduct it however you feel best.
I'll PM you with what I think Phil's e-mail address would be; the e-mail addresses all seem to follow a certain pattern so while I don't have his directly, I'm pretty sure I can figure it out.
In all fairness we didn't do any stretching and shrinking, the Panasonic deck did that as HD-SDI was the only interface. There is no way to test the DVCPRO-HD codec on the PC, so there was no way to test the codec other than using the deck. Even today the DV100 codec from AVID also does the same thing, expanding the 1280 image to 1920 and back again, so yes is a failure of the PC implementations and is something we would like to fix (we are pretty good at codecs on the PC.) ;) We have done nothing wrong and disclosed all our test procedures and even acknowledged the many of losses are due the resizing the deck as it must do to support HD-SDI. We also knew that the Apple implementation (at the time) was not very good as shown by the tests at onerivermedia.com (more than scaling issues); our test actually show the DVCPRO-HD does pretty well without any color shift and minimal color bleed -- just not as good as CineForm (and that was with our old codec.) I understand that we won't ever completely see eye to eye on this, its like a left-wing right-wing thing, doesn't stop us wanting to support this camera. Once there is readily available non-scaling codec implementation we will do our tests again, and post those results.
Thank you for the forwarding of Phil Livingston's email, Jan has already followed up so I email her with additional details.
David Newman
CTO, CineForm
www.cineform.com
