Emanuel
Cross-Examiner
Thank you mmm for your concern in answering!mmm said:Uncompressed 10bit holds advantages for filmout even if you only shoot with an 8bit codec. Stepping can be introduced in post if, for example you darken a scene. Of course film is analogue and can not be descibed in "bits." For DVD I don't think there is any advantage of using 10 bit unless you were doing multiple generation work on the image. 10bit will obviously retain more information.
Good question?...is there anybody with the answer...[1]Anyone know if the eye can see a difference between 10 and 12 bit?
Yes I know but:3:1:1 means the colour is recorded at 1/3 the resolution of the luma (black and white).
4:2:2 (same as 2:1:1) means the colour is recorded at 1/2 the resolution of the luma.
Obviously, the nearer to 1:1 the ratio is, the better.
http://www.dvxuser.com/V3/showthread.php?t=26672&page=3&pp=10
thisiswells said:It really all depends how you read/reduce numbers.
3:1:1 sounds like less than 4:2:2, but it's not.
The Sony has more luma information and the same chroma information as Panasonic
when in 1080i/p. That could be perceived as an "advantage"
DVCPRO-HD (720p & 1080i)
4:2:2 (15:7:7) 74.25, 37.125, 37.125
HDCAM (1080p & 1080i)
3:1:1 (17:6:6) 148.5, 37.125, 37.125
So?...what can we know about this? Is there anybody with the answer?[2]
