Not sure what you mean about HDV having a higher resolution, PerroneFord?? DVCPRO HD is a codec that records at a roughly 100 mbps data rate, with a 4:2:2 color sampling. The resolution can be 1280x720 or 1920x1080. HDV is a codec that records at a roughly 25 mbps data rate, with a 4:2:0 color sampling.
DVCPRO 50 is 720x480 at a roughly 25mbps data rate with a 4:2:2 color sampling.
Yeah. I think DVCAM is essentially DV. It just
happens to waste more tape.
@jrmmiller: DVCPRO50 does not have better color sampling than downsampled HDV. Downsampled HDV is practically 4:4:4 which is better than 4:2:2. And it generally has less noise. However, HDV might suffer from more motion-related more compression artifacts.
So your saying, theoretically speaking, that if HDV is compressed at the same rate as DVCPro HD (at 100mbps) then it would be a better format than DVCPro HD?
That would all depend on how you downsample it. Seeing as the color resolution of 1440x1080 HDV is 720x540, if you convert the HDV footage to a 4:4:4 codec and then downsample, the fact that the color res is higher than DV resolution means that you'll technically get 4:4:4 color.what do you meand by downsampled hdv is 4:4:4?
Choice of 4x3 or 16x9 aspect ratio without losing resolution
Yes. HDV at 100mbps will be sharper, less noisy, and exhibit fewer compression artifacts than DVCProHD. It's like using a bitrate of 25mbps for a standard def DVD. It's just too much. XDCAM has a maximum bitrate of 35mbps.So your saying, theoretically speaking, that if HDV is compressed at the same rate as DVCPro HD (at 100mbps) then it would be a better format than DVCPro HD?
Usually when people say "4:4:4" they mean "4:4:4 uncompressed" but downsampled HDV is "4:4:4 compressed" in the same way that DvcProHD is not the same as "4:2:2 uncompressed". They are all compressed. And here's the way I see the compression: In low motion scenes, HDV is definitely better (sharper, less noisy). In extreme high motion scenes, such as sports, DVCProHD is definitely better (no motion artifacts). In between the two extremes, it depends on the cam you're using. That's comparing the two HD formats.So HDV makes for pretty decent SD and web videos, but calling it 4:4:4 is an oversimplification.
