J Jov8 Member Mar 29, 2008 #1 When shooting DVC Pro 50...since this is n sd signal...does one need to set the camera to "Squeeze Mode" to use the entire chip set? Thanks in advance.
B Barry_Green Moderator Mar 29, 2008 #2 Yes. In standard def you can get either 4:3 ("norm" mode) or 16:9 ("squeeze" mode). If you want 16:9 on an HVX, you want to be in "squeeze" mode to use the full surface of the chips.
J Jov8 Member Mar 31, 2008 #3 Thanks Barry...One more question comes to mind.....Once you shoot in HD modes, do you need to worry about normal or squeez mode settings? Thanks again for this great site.
J Jov8 Member Apr 1, 2008 #5 I realize hd is always wide..but what should you set your camera on...Normal? Letterbox Squeeze?
B Barry_Green Moderator Apr 1, 2008 #6 You don't. Those settings don't apply when you go to HD; the choices are disabled because it will automatically be forced to widescreen mode.
