DVC-80 and Fluid Head Tripod - $1300
OdysseyTVShow
I'm upgrading to HD so I'm selling a DVC-80 for sale with 289 hours. Anyone who knows the DVX-100 knows that the DVC-80 is the same camera without the 24p shutter speed and the viewfinder is all black instead of silver in colour. Everything else is the same.
The TV series Odyssey: Driving Around the World was filmed on Panasonic DVC-80 cameras. see www.odysseyshow.com
Also included is an unused Davis and Sanford Provista Tripod with FM18 Fluid Head. Looks and works perfectly.
PANASONIC AG DVC-80
- 289 hours
- Battery Charger
- 1 longer life battery and 1 original almost dead battery
- lens cap
- svideo cable
- camera strap
- condition of camera ( shows some wear of paint around handle and body near viewfinder, everything is functioning great, zoom works fine but is missing the little screw know on the zoom for manual zooming but can be replaced with almost any similar fitting screw, heads should be cleaned for standard maintenance)
- Davis & Sanford Tripod Provista 75 with FM 18 Fluid Head - new never used - has been sitting in our equipment room taking up space. Comes with carrying case and baseplate.
Specs
Supply Voltage: DC 7.2/7.9 V
Power Consumption:
6.8 W (when viewfinder is used)
7.8 W (when LCD monitor is used)
9.2 W (max.)
Operating Temperature:
32°F to +104°F (0°C to +40°C)
Operating Humidity:
10% to 85% (no condensation)
Weight: 3.652 lb (1.66 kg)
4.034 lb (1.83 kg) with battery and cassette
Dimensions (WxHxD): 5-1/2" x 6-5/16" x 14-3/8" (139 x 160 x 364 mm)
[CAMERA]
Pick-up Device:
1/3-inch interline transfer type CCD x 3
Picture Elements:
Total: 410,000 pixels
Effective: 380,000 pixels
(horizontal pixel shift system)
Lens: Leica DICOMAR lens with optical image stabilizer, motorized/manual mode switching, 10x zoom
F 1.6 (f = 4.5 to 45 mm)
(35 mm equivalent: 32.5 to 325 mm)
Filter Diameter: 72 mm
Optical Color Separation:
Prism system
Optical Filter:
ND Filters, 1/8ND, 1/64ND
Gain Selection:
0, +3, +6, +9, +12, +18 dB
Shooting Mode:
60i (525i) interlaced fields
Preset Shutter Speeds: 1/60 (OFF), 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000 sec.
Synchro Scan Shutter:
1/60.3 to 1/250.0 sec.
Sensitivity:
F11.0 at 2000 lux Minimum luminance: 3 lux (F 1.6, 18 dB gain, 50 IRE video output)
[VTR]
Recorded Audio Signals: PCM digital recording
16 bits: 48 kHz/2 channels, 12 bits: 32 kHz/4 channels
Recording Tracks: Digital video, audio signals: helical track
Time code: helical track (sub-code area)
Tape Speed:
SP mode: 18.812 mm/sec., LP mode: 12.555 mm/sec.
Recording Time:
SP mode: 60 minutes, LP mode: 90 minutes
(when AY-DVM63 is used)
Tape Used:
6.35 mm wide metal tape
FF/Rew Time:
Approx. 85 sec. (when AY-DVM60 is used)
Sampling Frequencies:
Y: 13.5 MHz, PB/PR: 3.375 MHz
Quantizing:
8 bits Video
Compression System:
DCT + variable length code
Error Correction:
Reed-Solomon product code
[AUDIO]
Sampling Frequency: 48 kHz/32 kHz
Quantizing: 16 bits/12 bits
Frequency Characteristics:
20 Hz to 20 kHz
Wow & Flutter:
Below measurable limits
[CONNECTORS]
VIDEO IN/OUT: RCA x 1, analog composite input/output
1.0 Vp-p, 75Ω
(input/output automatically switched)
S-VIDEO IN/OUT:
DIN 4 pin x 1, Y/C separate signal input/output
Y: 1.0 Vp-p, C: 0.286 Vp-p, 75Ω
AUDIO IN/OUT: RCA x 2 (CH1, CH2)
Input: 316 mV, high impedance
Output: 316 mV, 600Ω
DV:
4-pin, digital input/output
IEEE 1394 standard
MIC/LINE INPUT:
XLR (3 pins) x 2 (CH1, CH2)
LINE/MIC switching, high impedance
LINE: 0 dBu
MIC: –50 dBu/–60 dBu (menu selection)
DC INPUT: 7.9 V PHONES: Stereo (3.5 mm diameter), 77 mV, 32Ω
CAM REMOTE:
Mini jack (2.5 mm diameter)
[EQUIPMENT]
LCD Monitor:
3.5-inch LCD color monitor,
200,000 pixels
Viewfinder: 0.44-inch LCD color viewfinder,
180,000 pixels
Internal Microphone:
Stereo microphone
Internal Speaker:
20mm round shape, volume – or +
