DV deck - Sony DHR1000
Sony DHR-1000 DV deck, low hours, priced for quick sale at $650.
Here are the specs- pics on request- pm me:
  • [FONT=Arial, Helvetica, sans-serif]
    [*]Digital Video (DV) Recording System: Digital Video Format offers over 500 lines of horizontal resolution, 3x analog bandwidth, and significantly higher S/N ratio, to provide stunning video performance. Component Video Recording dramatically improves color rendition and accuracy while reducing color 'smear'. PCM Digital Stereo Audio offers a choice of either: two 12 bit stereo tracks, for near CD sound quality, or one 16 bit stereo track for DAT quality recording. 180 Minutes Recording on 'standard' DV-180 cassette or 60 minutes on 'mini' DV-60 cassette
    [*]Video: Digital Comb Filter separates Y/C for cleaner, sharper, more detailed images Time Base Correction for jitter-free video performance Crystal Clear freeze frame and variable slow motion (fwd & rvs) playback 2x, 10x, 25x Playback for quick review of video playback 1/5x Slow Motion Playback
    [*]Editing Features: DV Interface In/Out provides multiple generation dubs with virtually no loss in quality 10 Segment Assemble Editor with Edit Window offers on-board assemble editor that's enhanced by Edit Window feature providing 'playback' window, and 'thumbnails' of all cut-in/cut-out points for easy review of 'cuts' Removable Edit Tray with Jog/Shuttle Dial detaches from the deck for convenient placement Camcorder Control controls camcorder or deck from DHR-1000 Edit Tray controller Video/Audio Insert Capability, Audio Dubbing Video On Sound (VOS) Editing capability allows you to replace video without affecting original audio (usually not found on consumer VTRs) Control L (LANC) compatible to interface with other video equipment Drop Frame Time Code for precise editing (compatible wiht RC Time Code Formats) Fine Synchro Edit provides A/B pre-roll for improved accuracy when editing Whole Tape Copy automatically records all data, (video, audio, sub-code data, etc.), with one DV cable, and the touch of one button Audio Level Meters with manual control of record, and balance levels
    [*]Audio: 12 or 16 bit PCM Encoding for near or above CD sound quality with 96dB dynamic range Built-in MTS Stereo Tuner receives stereo broadcasts
    [*]Convenience: Cassette Mechanism is compatible with both 'mini' and 'standard' DV cassettes, without the need for any adaptors. Cassette Memory can display data pertaining to 'search mode' on monitor screen. 3 Search modes: by index, date, or photo. Cable Ready 181 Channel MTS Tuner. VCR Plus+ System makes setting VCR Timer quick, easy, and convenient. 8 Event/1 Month Timer with Quick Timer feature for one-touch recordings. Sony's Cable Mouse remote repeater allows for unattended recordings of CATV or DSS broadcasts. Auto Clock Set from date and time data found in broadcast TV (where available). Camcorder Friendly Front Panel Inputs in addition to rear panel inputs.
    [/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT][FONT=Arial, Helvetica, sans-serif]Key Features[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
    [*]DV format offers over 500 lines of horizontal resolution (three times the bandwidth of S-VHS VCRs) and high S/N ratio for stunning Video performance.
    [*]Digital Component Video recording dramatically improves color rendition and accuracy, while reducing color "smear".
    [*]PCM Digital Stereo Audio offers either: Two 12-bit/32k Hz stereo tracks for near CD sound quality, or one 16-bit/48k Hz stereo track for DAT quality recording.
    [*]Three-hour recording on standard DV-180, or one hour on Mini DV-60 cassettes.
    [*]Digital Comb filter separates Y/C for cleaner, sharper, more detailed images.
    [*]Built-in Time Base Correction for jitter-free Video performance.
    [*]Crystal-clear Freeze Frame and Variable Slow Motion (Forward and Reverse) Playback.
    [*]2x, 10x, 25x normal speed Playback for quick review, as well as 1/5x Slow Motion Playback.
    [*]12-bit or 16-bit PCM encoding for above CD quality with 96 dB dynamic range. Built-in MTS stereo tuner receives stereo broadcasts
    [*]Audio level meters are provided for manual control of Record and Balance levels.
    [*]i.LINK (IEEE1394) DV Input/Output provides multiple generation dubs with virtually no loss in quality
    [*]On-board 10-segment Assemble Editor is enhanced with an edit window that provides a "Playback" window, and thumbnails of all cut-in/cut-out points for easy review of cuts.
    [*]Edit tray with Jog/Shuttle dial detaches from the deck for convenient placement. You can also control a camcorder equipped with Control L from the edit tray, via the DHR-1000's own Control L port
    [*]Video/Audio insert and Audio dubbing capability. In addition, Video On Sound (VOS) editing capability lets you replace Video without affecting original Audio.
    [*]Drop Frame Time Code for precise editing (compatible with RC Time Code formats).
    [*]Fine Synchro Edit provides A/B Preroll for improved accuracy when editing.
    [*]Whole Tape Copy automatically records all data (Video, Audio, Sub-Code data, etc.) with one
    [*]DV cable and the touch of a button.
    [*]Compatible with Mini and Standard DV cassettes without the need for adapters.
    [*]Cassette Memory can display data pertaining to Search Mode on monitor screen.
    [*]Search Modes; by Index, Date or Photo
    [*]Cable Ready 181-channel MTS Tuner.
    [*]VCR Plus+ system makes setting VCR timer quick, easy and convenient.
    [*]8-event/1-month Timer with Quick Timer feature for one-touch recording
    [*]Cable Mouse Remote Repeater for unattended recordings of CATV or DSS broadcasts.
    [*]Auto Clock Set from Date and Time data found in broadcast TV (where available).
    [*]Camcorder-Friendly front panel inputs, in addition to rear panel inputs.
    [*]Supplied RMT-X1000A Wireless Remote Control features a Jog/Shuttle dial and selectable VCR modes: VCR 1/2/3/4/5/6
    [*]DV Input/Output Connector x 1 (front)
    [*]A/V Analog Outputs: S-Video, Phono x 2 (rear)
    [*]A/V Analog inputs: S-Video, Phono x 2 (front and rear)
    [*]RF Antenna In/Out: 75 ohm
    [*]Headphone Jack (with volume control): Stereo Mini Jack (front)
    [*]Control L (LANC): Stereo Mini-Mini Jack x 2 (front and rear)
    [*]Control S Input: Mono Mini Jack.
    [/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT][FONT=Arial, Helvetica, sans-serif]Specifications:[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
    [*]Format Digital (Dv/Mini Dv) (Dvcam Playback Only)
    [*]Number Of Heads 4 Head
    [*]Audio Pcm Stereo 12 Bit 32 Khz 2 Stereo Tracks, Or 16 Bit 48 Khz 1 Stereo Track,Mts Stereo Tuner
    [*]Flying Erase Head Yes
    [*]Audio Dub Yes (12 Bit Mode)
    [*]Insert Editing Yes (Video Or Audio Or Both)
    [*](Random) Assemble Edit Yes 10 Segment Assemble Editor
    [*]Synchro Edit Yes W/ Control-L / Control-S / Dv Fire Wire
    [*]Time Code Drop Frame Time Code, Compatible W/ Rc Time
    [*]Control Protocol Yes Control-L (Lanc), Control-S
    [*]Time Base Corrector (Tbc) Yes
    [*]Dv Ieee-(1394) Firewire Yes
    [*]Line In Recording Yes (S Video/ Composite/ Dv-Fire Wire)
    [*]Tape Counter Yes
    [*]Jog/Shuttle Yes Jog/Shuttle
    [*]Audio Level Meter Yes
    [*]Manual Audio Level Cntrl Yes (Also A Audio Mix Balance)
    [*]Slow Motion Crystal Clear Freeze Frame, Slow Motion
    [*]Frame Advance Frame By Frame
    [*]Manual Tracking Yes
    [*]Vcr Plus Yes
    [*]Cable Box Control Yes
    [*]Program Timer Recording Yes
    [*]Auto Repeat No
    [*]Auto Tape Speed No
    [*]Rec. Speeds No
    [*]Playback Speeds No
    [*]Commercial Advance/Skip No
    [*]Front Audio/Video Input Yes S Video/ Rca / Dv Fire Wire/ Lanc Line (2)
    [*]Back Audio/Video Input 1 S Video 1 Rca And Control-S Line (1)
    [*]Back Audio/Video Output 2 S Video 2 Rca And Control-S 1 X Lanc
    [*]Headphone Jack Yes W/ Level Control Stereo (In Front)
    [*]Mic. Input Yes W/ Audio Control Mini (In Front)
    [*]Index Search Yes Or By Data Search
    [*]181 Channel Tuner Yes
    [*]Dimensions (W/H/D) 17"X 5 3/4"X 14 3/4"
    [*]Weight 21 Lbs 5 Oz
    [*]Power Requirements 23 Watts, Ac 120 Volts 60 Hz
    [*]Remote Yes
    [*]Jog Shuttle O/R Yes Jog/Shuttle Ring
    [*]Multi Brand Remote Yes
    [/FONT]
[FONT=Arial, Helvetica, sans-serif][/FONT][FONT=Arial, Helvetica, sans-serif]Additional Information:[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
    [*]Photo Search
    [*]Data Search
    [*]Built In Tv Tuner
    [*]Insert Editing
    [*]Audio Dub
    [*]Assemble Editing
    [*]Manual Audio Level Control
    [*]Mic Input
    [*]Head- Phone Jack W/ Level Control
    [*]A Built In Edit Board
    [/FONT]
