Duel adapter problem
Viktori
Hello! I have a Macbook Pro 10.5.8 and Duel Adapter to offload my P2 cards. I have used the Duel Adapter several times but not for a while. However, I do have a shoot coming up, where I will need to offload while shooting. I haven't been able to get the Duel Adapter to be recognized. I thought I might have accidentally deleted the P2 driver and I downloaded the latest one from the Panasonic website. The P2 card still does not show. I've read several posts here with people having the same issue, but did not see any solutions. Can someone help? Could it be that the model of the P2 card is not supported by the current driver? The P2 cards are AJ-P2C016RG... I had a similar issue when I first got the Duel Adapter, but after I downloaded the correct driver, it worked. I would appreciate any ideas. Thanks!
Did you upgrade your OS to Snow Leopard? If so, you're sunk. The Dual Adapter isn't complient with Snow Leopard.
Are you making sure that the Dual Adapter is plugged in during boot up? If not, then try that.
If none of these work, then you may have a defective Dual Adapter. Now that the Dual Adapter is discontinued, you may have to purchase a PCD2.
http://www.spec-comm.com/store/index.php?l=product_detail&p=3684
In-Stock!
Andrew Hoffman
