dubbing from HVX202EN to 1200 deck
chriskamen
Simple question:
Is it possible to dub from the HVX202EN (the Aussie PAL version of the HVX200) to the 1200 deck using Firewire?
This seems like a good workaround at the moment for working with 720p25 DVCPRO-HD footage that isn't yet supported in Final Cut Pro. If it is possible, then the P2 footage could be dubbed to tape, and then could be played off the tape as Uncompressed video through the HD-SDI output of the deck. Import the uncompressed footage into FCP using a DeckLink card....
Anyone been able to do this?
Nope - just trying to figure out how we're going to edit 720p25 footage with it when we do get it.
Yourself?
I'm used to a Varicam workflow using the 1200 deck. Record with Varicam at various frame rates, then use the deck to output Uncompressed 10-bit and capture at 25FPS through decklink card..
