Dual Monitor Setup?
mdreuben
We just got the Panasonic LH1700W monitor to go with the HVX200.
In a studio configuration I would like to be able to view the image not only on the LH1700 monitor, but also on a conventional CRT TV as well. This is a 20" Sony that only offers S-VHS and Composite inputs. I've found that my ad agency clients really like this "safety factor" of seeing what things look like on a "real" TV. If I'm shooting 480p I can go out from the camera's S-VHS and into the same on the Panasonic. But if I'm shooting at 720p I want to go component out into the Panasonic's componenent in.
I've tried going from the S-VHS outputs of the LH1700W to the Sony, but am not getting a picture. Is the S-VHS setup in the LH1700W a passthrough only?
How can I view images on both monitors at the same time when shooting 720?
Thanks!
Not sure, but it sounds like you'd need some form of downconverter in the chain. The HVX disables composite and s-video when the component output is connected, so you can't get the signal from there. And I'd assume that the 1700 is a pass-through only, so... presumably some sort of signal downconverter from the 1700's outputs to the sony's input would be required.
