robotsound
Has anyone figured out a way to import and export DSLR footage (without AMA) and get the output to look identical to the input?
The goal is to import a single Canon DSLR clip, immediately export it, and have them both look identical. If this can be achieved, then the Avid won't mangle any footage, and just pass it straight through. Should be simple, right?
Here are the things I have tried systematically so far. Each of these results in footage that looks different than the original (when viewed in both QuickTime 7, with the Final Cut Pro Compatibility setting checked, and QuickTime X).
Set project to RGB 709 / Import clip as RGB / Export clip as Quick Time Animation RGB
Set project to RGB 709 / Import clip as RGB / Export clip as Quick Time Animation 709
Set project to RGB 709 / Import clip as 709 / Export clip as Quick Time Animation RGB
Set project to RGB 709 / Import clip as 709 / Export clip as Quick Time Animation 709
Set project to YCbCr 709 / Import clip as RGB / Export clip as Quick Time Animation RGB
Set project to YCbCr 709 / Import clip as RGB / Export clip as Quick Time Animation 709
Set project to YCbCr 709 / Import clip as 709 / Export clip as Quick Time Animation RGB
Set project to YCbCr 709 / Import clip as 709 / Export clip as Quick Time Animation 709
I've also tried exporting to DNxHD in a QuickTime wrapper (the only choice for DNxHD it seems), and bypassing QuickTime entirely and exporting to a sequence of PNG and TIFF files, all with similar results. Some export closer to the original than others, but none of them match entirely, and they're all over the map.
Surely I can't be the only person who has ever tried to do this.
Does anyone have a reliable non-AMA Avid workflow for working with Canon DSLR cameras?
