Well, here's some food for thought:
The Mark II does NOT record in 24fps, only 30. That in itself will give the footage a more"Video"look.
The HVX does record in a "Cinemode" (24fps)
The sound on the MarkII leaves ALOT to be desired. I did a commercial with it and although the footage came out fantastic the audio sounded like Helen Keller stuck in a box. Good thing I had a Z1u to record the sound.
The HVX does have good sound. Certainly WAY better than the Mark II.
The MarkII has the ability to change out lenses for certain artistic or lightning needs.
The HVX does not have interchangeable lenses.
Peronally I would buy the HVX if you're going to make a movie. If you're going to take pictures then go with the MArkII
Thank you for reply!
I'm happy to hear that you'd experience shooting Mark II. My big question is: Does motions in the video shot by Mark II difference from those shot with any camcorder (24p or 60i)? This "different" here, I mean "worse", or "not as smooth as" etc. Regarding sound, I don't concern it because I plan to record that with a separate sound recorder anyway.
Looking forward to the reply! Thanks!!
Here's the footage from the Mark II
http://vimeo.com/5313638
It is very smooth and colors are good right out of the box. Just a small touch of color correction was needed to realyl get them to pop. This was with a Tamron 2.8 lense.
