Hi there,
I'm stumped about what to get... I know I want a Drylin slider but I don't know if I should get parts from Igus direct (I have no problem tapping holes and sizing stock) or if I buy a kit from Amazon. There are kits on Amazon (from Igus) for as low as $100... but there's the W1040-A, W1040-B, W1080, etc. etc. I don't know which one I need
On DVXUser I found suggestions for buying parts direct from Igus: 16-60-10 and 16-60.
I currently have a Canon 550D (t2i) which is very light. But very soon I will be upgrading to a 5D Mark III. I know the 5D is a much heavier camera. At times it may have a zoom lens which also bumps the weight up. And finally, almost always there will be a Juiced Link mixer mounted to the camera. So, I guess I'm not sure what I will need as far as height bearing. I understand with friction the lighter the better.
Ideally I would like to have a 2 foot portable track that mounts on a single tripod and MAYBE also a 4 or 5 foot track that mounts on c-stands, light stands, table, etc. This is why I was leaning toward buying direct (get a long piece to cut down). Again, I can drill or modify easily. But the parts list I found on this forum seems to be more expensive than some of the Drylin kits on Amazon. But the problem is that I don't know the differences between them. I assume the kits are either lesser quality (dimension-wise) but I don't know for sure. I've done DIY things before only to find that the manufacturer offers a pre-made "kit" at the same or lesser price...
So, can anyone give me some advice for a portable (and maybe additional longer) Drylin slider (either kit or parts list) that will work easily on a heavier DSLR camera setup?
Thank you for any suggestions!
-Stephen
-Stephen
