paulcurtis
I'm rejigging my system all around, and i have a dreamcolor here now. This perhaps isn't the ideal forum but i know Nirv, Dermot and Frank all use these and so i want to pick their brains about the best way of working with it.
I need full RGB progressive over HDMI, to use the colour engine.
There doesn't appear to be a single box that does that, or is there now? The BM range seems to offer only YUV. There is a Kona card but that's a lot more expensive (and i'm not sure it's supported in CS6 either which i also need - i need CS6 and Resolve at least plus a route to get FCP X off the macbook onto it to ideally)
So perhaps i can ask the brain trust here how they are connecting their setups?
Are some using the monitor as a second monitor via a Quadro card for example? (over display port?) I presume you loose all the video signal syncing and frame rates?
many thanks
paul
many thanks
paul
