Hi!
I am Begining to have some problems with my F35 Lately,
i get Warnings about DPR and TR boards more consistently.
Before i just ignored the warnings when and and if they came up, usually they came when i have changed between IF-box and Otto-nemenz plate for Codex or the Original recorder,
i assumed that it could be some some confusing settings change, conflict of protocol or somthing, but a restart always solved the problem, it didnt appear offten so i just forgot about it.
But now it does happen almost all the time, usually its fine the first startup of the day, but if i restart the camera for any reason i always get the warnings, if i wait to about 10 minutes or more it can work but not always.
i assume it has to do with actually starting and getting power to the boards, because i have never any other problems when it starts correctly and it is always both DPR and TR warnings, never one of them at a time.
and i know they have somthing to do with the docking connections because they stop working.
i had times when i used bad batteries that had quick voltage drops under the 10.5v working level without killing the camera, i think that may have damaged or just weakened some power handling components, but that may be false.
Have you Guys had this problem?
