TheYankee said:It might be the flux capacitor. If you submerge it in distilled water for 30 minutes it should go into reset mode.
oneinfiniteloop said:My favorite out of both threads.
It could also be a CCD charge. I've always recommended resetting the phospher charge of the CCD's through the blackout method. This happened to me, and this is what I did to fix it:
1) set the dvx up in a pitch dark closet, and turn it on.
2) make sure NO light gets in, you're effectively resetting the CCD's to their "true black point", by letting absolutely NO light hit them.
3) Keep the camera in this true black for at least 15 minutes. You may want to sit in the closet with it to avoid any light getting in when you open the door to get out, etc.
4) That should do the trick.what about the tin foil hat?? he can't do that without a tinfoil hat...right???
PK Gillock said:his johnson rod might be out of whack. It happens to everyone, once and a while.
OregonDank said:i love this forum...
mikkowilson said:Vidled get's a few points for his "repair service"...
:grin: :grin: :grin: ... and of course... :violent5:
Did you stage that shot just for this Vidled? :huh:
- Mikko
