Don't know if Footage is 24p or 24pa - HELP!
Fliques Osman
Hey guys,
I just got a job that needs to be done soon. However, the person who shot the doc shot both in 24p and 24pa.
Is there anyway I can check with my DVX100b which tapes where shot using 24p and which tapes where shot using 24pa.
Thanks,
Which NLE are you using? If you're using Edius, Vegas, or Premiere, it doesn't matter.
Otherwise, the cam should tell you which it is in the LCD when you play it back.
Right, use the "counter" button to cycle through the available options, one will be "FR" and that'll tell you the frame rate the tape was shot at.
