jgastelb
I built a skateboard dolly a while back. It was made with the internet plans you normally find when using the google search. Anyways, I have been having problems with the skateboard wheels falling off. I should mention I'm not the DIY kinda guy. The problem seems to be that I didn't include a washer so I went and got some but the wheels would still start sliding off. Then I thought about adding lock nuts to prevent this from happening altogether. Well... everything went downhill from here. The first wheel lock nut worked and it was fine once I got it in there. It took me some time just to get that one on. By the 3rd wheel my hands were hurting because the luck nuts have to be forced into the bolt by using two wrenches going in opposite motion. Unfortunately, my left hand slid off crossing some of the metal channel which was sharp cutting into my thumb. I had to get three stitches and 50% of my tendon was clipped. Regardless, I'm very fortunate not to have done more damage.
Questions:
Q. Should the lock nuts be this hard to get onto the bolt?
Q. Should I try a different method to keep the wheels from sliding?
Any ideas. I, more than likely, will have to pay someone to finish the job. I just don't want someone else to get hurt while doing this.
Thanks for any help!!!
Jgastelb
Questions:
Jgastelb
